5 meters on M radios
Rich McCabe
Member ✭✭✭
I assume this is a bug.
The manual says "The value displayed in each meter can be selected from a set of five meters by tapping on the meter."
On my 6600M I can hit the plus and get six meters. Nothing new to select so one would always be a duplicate I think.
Rich
kd0zv
Rich
kd0zv
It's a doc issue. This was a holdover from the Maestro doc. Thanks for pointing it out.0
Tim, not a software issue too? Why have six meters on the 6600m when there are only 5 types? At least I think so. Unless one is for use on second panafall and I did not catch it.
Rich0 -
I'm looking into it.0
FYI
That helps. Looks like a bug. I added it to the bug tracker as issue #60080
on the 6400M I can display more than 5 meters as well, but they are duplicates!0
There are more meters depending on what hardware is present (aka Power Genius). This also leaves room for expansion when/if we decide to add more meters.
One can never have enough meters ;-)
Don’t forget several meters for PG XL integration so you need the room for the extra meters. Dave wo2x0
Is that coder speak for, oop's we overlooked that! ? It's not a bug, it's a Feature!0
Well there is a mistake somewhere because it does not match the manual
I can see having the extra space available but no reason to turn on extra duplicate meters unless the option (PGXL as an example) is installed.
Someone didn't pay close attention and keep a count of Objects/Controls, as they are created or destroyed as needed. Simple coding error that even a truck driver could make! :-)0
Now that you have your radio, you are getting pretty sassy James
Meeeeeeeeeeee??????? Yeah, you're probably right. But, I was writing code for my 6300 and then the 6500 when I had them. And errors like the above were common,,,,,,,unfortunately! But, since I was not only the coder, I was the Beta tester too. Plus, I was my only user! So, I could get away with stuff like that. But, I had to toss out a little tease at Steve and Eric too. (keeps them honest!)
At the time the documents were written, there were 5 distinct meters that could be assigned to any of the six slots. The number of slots is set by the screen real estate; the number of meters that you can select from is determined by the configuration of the radio system.
For instance, when the PowerGenius XL amp is connected, three additional meters are available (I think it is three), so the six slots could be taken up quickly enough.
Yes, threeadditional meters with PG XL Dave wo2x0
Yea I get all that. But with "software" radios there is no reason to have one extra meter slot available for hardware not installed. Since the PGXL has three, adding one appears to just be a mistake. No big deal.
Just trying to figure out a discrepancy from the manual.
As discussed in this morning's defect review, the engineers are much more likely to create more meters to fill that open slot than to remove an "extra" one.0
Thanks Eric.
Just to be clear, the -4V to 0V ALC is for the amplifier? So there are 4 usable meters for the actual radio ? I did not see this in the manual. Just this.
When the meters are displayed, the panadapter(s) are made narrower and move to the left side of the display; the meters are displayed on the right. “Plus” and “minus” buttons are displayed below the meters. Tapping the “plus” button adds a meter, tapping a “minus” button removes a meter. The value displayed in each meter can be selected from a set of five meters by tapping on the meter.
So just ignore two of the slots when dealing with radio only?
Rich
The ALC is actually a radio meter for the ALC interface on the radio for use with older amplifiers that require an ALC circuit. We do not use this with the Power Genius, nor is this interface recommended unless absolutely necessary.0
Since there are 6 meters, can one be programmed to be a volt meter so one does not have to run a third party program? I know it is going to take a software tweak to do this,0
That is a good idea Rick. Dave wo2x0
This is a reasonable ask and is certainly technically possible. I will put this in our system (#6046).0
Temp would be nice as well
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 912 Maestro
- 52 FlexControl
- 855 FLEX Series (Legacy) Radios
- 876 Genius Products
- 315 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 729 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
