No Tx Menu
Bob W8RMV
Bob W8RMV Member ✭✭
While operating my 6400M in rig mode, when I push in the Mic/Speed PWR knob to access the Tx Menu, nothing happens.  According to pg 145, it should bring up the Tx MENU.  It has the latest s/w.  Any suggestions?
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    edited February 2018
    No suggestions for you Bob, but just wanted to comment that mine does work as the manual suggest.
    Rich
  • Tim - W4TME
    Since this looks to be a hardware issue, I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  Please respond using the HelpDesk ticket for issue resolution.
  • Homer1952
    Homer1952 Member
    Turned out that the outer knob was too close to the inner. I removed the rubber ring from the knob & loosened the hex set **** & moved it out a touch. Apparently, the detent happens before the electrical connection.  Not sure that is the best way to design the switch.  Ideally you'd want the detent feel & switch make up to happen at very nearly the same moment.  A nice 6 Sigma design project for that manufacturer.
    Anyway the TX MENU now works.  Simple fix & thank you Dudley at Flex for the suggestion.
    73 Bob W8RMV
  • K3SF
    K3SF Member ✭✭✭
    edited March 2020
    bob
    thanks for the description of the fix...these types of follow ups are greatly appreciated by the community at large...
    i know when my 6600M arrives and if it experience similar fault that it is easy to fix with guidance from the help desk and is an easy DIY fix..
    tim & dudley...good job guys in these busy time
  • Mike KB0FX
    Mike KB0FX Member
    edited January 2020
    I just had the same problem with my Maestro. It seems Flex should be testing this function prior to shipping in my opinion.
