No Tx Menu
Bob W8RMV
While operating my 6400M in rig mode, when I push in the Mic/Speed PWR knob to access the Tx Menu, nothing happens. According to pg 145, it should bring up the Tx MENU. It has the latest s/w. Any suggestions?
No suggestions for you Bob, but just wanted to comment that mine does work as the manual suggest.
Rich
Since this looks to be a hardware issue, I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. Please respond using the HelpDesk ticket for issue resolution.
Turned out that the outer knob was too close to the inner. I removed the rubber ring from the knob & loosened the hex set **** & moved it out a touch. Apparently, the detent happens before the electrical connection. Not sure that is the best way to design the switch. Ideally you'd want the detent feel & switch make up to happen at very nearly the same moment. A nice 6 Sigma design project for that manufacturer.
Anyway the TX MENU now works. Simple fix & thank you Dudley at Flex for the suggestion.
73 Bob W8RMV0 -
bob
thanks for the description of the fix...these types of follow ups are greatly appreciated by the community at large...
i know when my 6600M arrives and if it experience similar fault that it is easy to fix with guidance from the help desk and is an easy DIY fix..
tim & dudley...good job guys in these busy time
I just had the same problem with my Maestro. It seems Flex should be testing this function prior to shipping in my opinion.0
- 713 The Flea Market
- 210 SmartSDR+
- 466 SmartSDR for Mac
- 128 Aurora
- 991 Genius Products
- 330 Shack Infrastructure
- 234 Networking
