RemoteQTH and Rig Control
AA0Z
Looking to remote my 6700 and use RemoteQTH as the brains of the operation for remote on, antenna switching and other stuff.
I've seen a YouTube video on how someone got the QTH server to connect to a Flex via USB and follow band data for automatic antenna switching, but doesn't really explain how it was setup. That's what I'm looking for.
There is zero documentation on the web on how to accomplish this, even on the RemoteQTH forums, there is only a few posts regarding connecting a Flex. I'm wondering if anybody in this group uses RemoteQTH to get band data from their Flex for auto switching and how you specifically set it up?
If you don't use RemoteQTH, what do you use to accomplish this? Green Heron? 4o3a IP switch?
Hi, I use the USB to BCD cables to connect this cable to the BCD input of the 4o3a antenna switch. Most switches accept BCD coded steering.
I run a fullly remote operated 6700 with no PC at remote radio end. You may also connect the 4o3A antenna Genius switch to the 6700 over LAN and then steer it with a local PC which have the Windows applicaton över a VPN tunnel between local PC and remote radio LAN.
73s See at my blog http://remotedxandcontestblog.sm0hrp.se0 -
Hi Kyle,
I read just now your message. I was able to connect RemoteQth to my Flex 6300 and now I can control the whole station from my web browser. In the last weekend I added support for Prosistel rotator control via RemoteQth.
If you still need it you can go on this post or you can send me an email. What is your issue?
Regards, Enzo
iw7dmh
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
