Sold my Flex6300 V2
Jean Drolet
I sold my Flex6300 with SamrtSDR version 2, if I erase my radio by pressing the button for a long time. Will the new owner be able to reinstall SmartSDR version 2.?
Should we make a transfer
The software license is in the radio permanently. A factory reset will not remove the license.1
SmartSDR is tied to radio SN. Doing a factory reset will not erase 2.0. There is no need to do a transfer. Mack W4AX Alpha Team1
Doing the "Factory Reset" won't uninstall the software in the radio. It erases the stored Profiles and Persistence data. It also doesn't erase some of the radio settings, such as Network preferences (DHCP v. Static, etc.).
The SmartSDR Version 2 license stays with the radio. The new owner can install whatever version of the software he prefers (V1 or V2) and the radio will be updated to that version. He should take the time to look through all of the radio Settings to be sure they are what he would like. If you sent the radio to him in the "Factory Reset" state, then he won't be able to restore or use your profiles.
Thank you Tim, Please send your Flex6660M to Canada quickly I have no flex in 3 days0
I just sold my Flex 6500 and Maestro What is the best way to clear both of them out and still leave the new 2,0 in tack0
Start the radio and open Settings->Radio setup. In the radio tab, remove and nicknames and calls that are unique to you.
Power off the radio. Power back on and hold the power button until it flashes white. This will reset the databases back to the factory defaults.
That is it.0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
