Is there no eight pin Foster type mic connector option for the 6400M? How will I use my Heil xlr mic
Michael Blaine
No Foster mic connector for 6400 series?
I usually make an adapter cable, XLR to whatever. I have several for using my Heil on several different rigs with different mic connectors. Cheap solution.2
I have a lot of different mics, and different connectors on their ends. Have either pigtail box or an adapter for all of them.0
That is correct. The radio uses a 1/8" TRS pseudo balanced mic input. There are a plethora of adapters you can buy or make one.0
Can a 1/8" TS unbalance plug be used on the mic input? This is typical connector in Heil Headset for the Mic.
Yes. Refer to the New Product FAQ for additional product details.
http://www.flexradio.com/downloads/new_products_faq_v1-2-pdf/0 -
Tim, Where can I find the Foster pin assignments for the Flex pigtail that I ordered for my 6400M? Wonder if it matches one of the Big 3 radios?
Thanx Bob W8RMV
yaesu0
Thank you, Larry.
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 41 Aurora
- 955 Maestro
