Best State of the Art Remote Rotator Controller
A group of us have placed a 6500 in our "club" room. It has a 3 El Yagi, with a 40 m dipole and a very old rotator. The controller is the 40 year old "flip the lever left or right" and watch the needle.
Obviously the controller needs replacing to have remote operations, and probably the rotator also, given it's age.
Recommendations? Who has the slickest interface for the remote operations. Direct control of the controller from the remote computer, or do you have to remote into the local computer?? Is there automatic control of the controller with DDutil, or does that even work remote??
I'm sure there are several ways to skin this cat. Looking for something simple, but elegant.
Thanks, Brent W8XG
Great question! I too would be interested in an easily remote-able rotator big enough to handle a mid-size 3 element tri-band beam and a 40 meter dipole. I may get the opportunity to **** a remote tower in the next year or so, and while I'd prefer a directional solution, a cobweb Antenna was looking like my best answer (no rotor) but they seem too fiddly for a remote solution.0
I would suggest a rotor supported by PSTRotator. That software is slick and you can set up a web page for remote access and it interfaces to a lot of popular logging programs for getting azimuth info from cluster spots. I use it with a Yaesu G1000 rotor with a serial interface installed and three different logging programs, N1MM+, HRD Logbook, and Log4OM. Dave wo2x0
Let me toss in what works for me.
I have been operating for 12 years remotely. As part of my solution with multiple operating locations, I decided to have a PC at the remote end.
I finally decided on PSTRotatarAZ due to its multiple integration parts.
http://www.qsl.net/yo3dmu/index_Page346.htm
This talks to the RS232 port on the Rotator Controller. In my case, it also controls my Steppir, etc.
Take some time to review all the parts.
For simple Beam Control it does have a web interface too. Here is what the web interface looks like from a remote connection and it looks good on an iPhone too.
Mike va3mw
I was on a budget so I took a Yaesu G-450 rotor and control box ($279.95) and added a Easy Rotor Control ERC V4 USB Rotor Control mounted in G-450A CB ($100.00). It's connected to my remote shack computer via USB and integrated with HRD Logbook. Works great.
Cal / N3CAL
The Ham-M / Tail twister type rotor does not have remote control, but I have installed the "Rotor-EZ" control board that mounts in the controller and now have remote control of the rotor. Might be less expensive than buying a complete new rotor/controller that has USB or RS-232 control. I haven't used the programs listed above, but it does work with Ham Radio Deluxe... just click on the country and the antenna starts turning!0
Check out Green Herron Engineering.... Jeff is always very helpful, and his controller is wifi enabled, and easy to work remote.
Diddo on the Green Heron Engineering. Have mine for many years and remote operating is seemless.0
This is an old thread, but I figured I'd leave a breadcrumb for those that may stumble upon it.
A newer option on the market is 4O3A's Rotator Genius. I use a Green Heron RT-21 and it has served me well, but if I was buying today, I'd give the Rotator Genius a good look.
They note it "Will be integrated with FlexRadio SDR and the Maestro panel in a future software update." 73
I use the FT21 and have it connected to my Node Red server. It, along with other equipment is available for control and monitoring via any web browser.
Dave wo2x0
- 337 Community Topics
- 604 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 182 FLEX-8000 Signature Series
- 913 Maestro
- 885 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 740 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 951 Third-Party Software
