USB-cable ?
Hello,
I have a problem with Flex-6300 from a friend. I explain to you. He installed the latest version of Smart-SDR 1.11.12, he is under windows 7 and an Ultrabeam antenna. We have to connect Flex with the Ultrabeam box with the recommended cable.
Unfortunately, its cable does not appear in the USB-cable window. Do you have some ideas ?
The USB cable must use an FTDI chipset to be recognized. 73, Mack W4AX Alpha Team2
No problem it's the good cable an FTDI chipset
If it is a good FTDI chipset then I would see if you have another one to try just in case it is defective. If you have done all ready I would then open a helpdesk ticket to assist in diagnosis.1
Yes I think there is a cable problem because at home it works and so another ham radio that has the same configuration.
I found a source of inexpensive quality USB to RS232 converters. I cut the cable to required length and replace RJ 45 connector with a DB9 plug.
https://www.ebay.com.au/itm/USB-to-RJ45-For-Cisco-USB-Console-Cable-FTDI-744664241835-X2K7-M1R2-L4F7...
Tom, SP7WT
- 632 The Flea Market
- 123 SmartSDR+
- 195 DAX
- 40 Aurora
- 953 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
