TX Input DAX sampling rate
Geoff_W8GNM
Geoff_W8GNM Member ✭✭
edited February 2018 in FLEX-6000 Signature Series
The sampling rates for the I/Q DAX inputs are visible and adjustable.   What is the default sampling rate of the DAX Tx input?  Is it adjustable or does it have a sample rate converter?
Has anyone used the NCH Tone Generator through  the Tx DAX connection?  What is the correct sampling rate to correctly transport audio tones to the Flex 6600M?
  • Tim - W4TME
    It is 48kHz
  • Bob- W5TX
    Bob- W5TX Member ✭✭
    I’ve not used NCH tone generator on my 6600M but had done so previously on 6300 to do two tone testing. Since specs are the same I believe you should have no problem
