TX Input DAX sampling rate
Geoff_W8GNM
The sampling rates for the I/Q DAX inputs are visible and adjustable. What is the default sampling rate of the DAX Tx input? Is it adjustable or does it have a sample rate converter?
Has anyone used the NCH Tone Generator through the Tx DAX connection? What is the correct sampling rate to correctly transport audio tones to the Flex 6600M?
It is 48kHz0
I’ve not used NCH tone generator on my 6600M but had done so previously on 6300 to do two tone testing. Since specs are the same I believe you should have no problem0
- 688 The Flea Market
- 105 Aurora
