fldigi + 6600M - hamlib?
David Orman
Has anybody gotten fldigi working with the new 6400/6600 series using hamlib vs. rigcat? I see there's a Flex 6xxx option in Hamlib, but haven't had success using it. Before I go download xmls and work on the rigcat setup, I thought I'd check here.
If rigcat is the 'better' way, I'll just do this - I've only used hamlib in the past, so default to trying to use it first. I did see a rigcat tutorial on a blog post from late last year that I will attempt to follow if that's the better route to take, Hamlib just seemed more integrated/easier to configure, assuming it works.
David -
Look here, it may help: https://sourceforge.net/p/hamlib/mailman/message/36167703/.
73 - David, AG4F1 -
RigCat has more functionality than Hamlib. And as an added bonus, it works regardless of the FLEX-6000 model.1
Tim -
Any idea if OmniRig will work with the Flex 6400/6600? I have used that from within Excel to have spreadsheets control rigs. It's very easy to use as a referenced library in VBA. It's slower tham Hamlib, but it's also much easier to use for casual stuff.
73 - David, AG4F0 -
Has a new RigCat XML Slice file been written to work with 6400/6600? In Fldigi split mode my 6400 TX goes to receive slice even with slice B locked on TX? Tried XML Slice A & B to no avail. Please advise. Thanks,0
Omnirig will work fine. Dave wo2x0
Yes, FLDigi needs to update Hamlib to support the new radios. Good news is as Tim said, uae RigCat. Dave wo2x0
The RigCat files work with all FLEX-6000s.
How are you enabling split in Fldigi?0 -
I am not configuring split in Fldigi. However, I think I solved my problem by disabling the auto switch tx slice on the smartcat serial port for Fldigi. Is there a better way?0
OK. Enabling "split" in a digital mode programs means something very different than working split. There is a very specific set of CAT commands that put the radio into "split mode" and when it that mode, it processes CAT commands specifically for VFO A and FVFO B very differently. That is why I was asking since I was not aware that Fldigi has a "split" mode of operation.0
i run the 6700 same software for 6600 and 6400 put the b vfo on dx station then use a to tx it,s easy to split rtty
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 918 Genius Products
- 295 Shack Infrastructure
- 207 Networking
