6400 no SSB TX Audio - Solved
Joe N9VX
I setup my new 6400 yesterday and could not get any SSB TX audio out. After spending 30 - 40 minutes looking for the problem, I found DEXP was on by default and set at a high level, it was not allowing any audio to pass. So I turned it off and have SSB TX audio now.
Just thought I would post this and possible save someone else some time.
2
What is DEXP?
Just got my 6400 today - haven't transmitted yet. Receive is spectacular...
http://www.arrl.org/files/file/QEX_Next_Issue/2014/Nov-Dec_2014/Hershberger_QEX_11_14.pdf
DEXP - Downward Expander - aka CE-SSB. The magic is done in the DSP (?) and yields about 2dB more 'talk power'.
I've had mine at 50% w/o the aforementioned problem...
Congrats on the new radio!
k3Tim
It is my understanding that DEXP (Downward Expander) is a form of noise gate that shuts down back ground noise (fan and etc) while transmitting on SSB . On Apache Lab SDR radios you have both DEXP and CESSB, so I think they are two separate functions.0
SmartSDR has DEXP and CESSB too. They are separate audio processing functions that do different things.0
Gents, just put my 6400 online and no SSB TX Audio via the handheld mic .. turned DEXP on and off and nothing .. all suggestions welcome ... do I have a bum brand new mic .. unlikely .. all help welcomed .. love the full duplex CW .. need to get SSB going now .. Thanks Ed W2MKM
Hi Ed
Did you make sure you have the right Mic input? You didn't say what you had looked at yet.
Have a look at the SmartSDR Software Users Guide starting on Page 62 where it discusses Mic profiles, etc.
http://www.flexradio.com/downloads/smartsdr-software-user-guide-pdf/
Ed,
If you are using the M version radio, in my opinion Flex's method to choose microphone inputs is not very clear and the manual does not do a very good job explaining it.
The microphone selection on the left needs to be highlighted. In the picture below I am running balanced line input.
To me this looks more like a menu to setup various inputs. But the audio input will not work unless you leave it on the proper input on the left.
In other words, if I setup my balance line input the way I want and then click the MIC on left, my balanced line wont work because MIC is actually selected.
Rich
This might help. I grabbed the description from the Maestro Manual as I had it handy.
Mike/Rich,
Thanks for the replies ... much appreciated ...
Mike, yes I've been through the Mic profiles section a couple of times and while not intuitive ... I think I'm getting it .. though I do appreciate the link to the V2.0.17 of the SmartSDR SW Users Guide .. I was down rev.
I have triple checked that I have connected the Flex FHM-2 Hand Mic that ships with the 6400 to the correct PTT (RCA) Port (PTT works) and 1/8 mic port in the back of the radio (still suspecting a bum mic .. but that's too easy a hypothesis)
Rich, I'm running just the 6400 (non M version) so not seeing exactly the same screen that you included ..
Here's mine .. still no joy ...
I think I read the factory mic is a condenser mic and needs the mic bias turned on in the setup. I would think the Flex profile would turn that on but you might want to check
Rich
BINGO ... Thanks Rich .. silly me to not have known that the Flex supplied FHM-2 handheld mic was a condenser and that the Bias has to be enabled ... a quick Ctrl-F on Bias and your comment got me there ...
From the SmartSDR window main menu bar - Settings>Radio Setup>Phone CW Tab> Microphone Box - click on Bias ... and you/I am in business ..
Love the puzzle .... others may not so much ..
Thanks guys
That's great Ed. Glad its working.
I would think this would be considered a small bug as the FHM-2 profile should turn on BIAS. This is something that is retained in MIC profiles.
Rich
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
