SmartSDR update not updating
Andrew O'Brien
Member ✭✭✭
I held off for a while but today I decided to move 2.1.30 . The radio is recognized but when I click on "update", it eventually hangs without any update progress . Windows 10. I DID do a reboot after the install.
Did you see the radio firmware update on the radio by the power LED turning purple?0
I took the back roads to this issue and things seem fine. Went backwards from .19 to .17 and did the update to .30 and Updater is now making progress. The fan coming on and the flashing purple LED caught me off guard though. Update completed
Andy K3UK1 -
I always reboot my radio and do an export of my profiles (if they have changed) before every upgrade and have never had a problem with the firmware not updating. Occasionally I have to manually reboot, but usually not. And I change firmware in my radios several times a day. More if I am testing new code.1
You change the firmware in your radios several times a day? Can you explain? (understand testing new code) thx
I am responsible for supporting the SmartSDR v1.x and v2.x code streams.1
got it. FB. thx
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
