Quadra connection to Flex 6300
Larry
can someone help me understand how I might connect my yaseu vl 1000 quadra amplifier to the flex 6300 so that it provides band change and frequency information. I use HRD software.
I use the 6500 and the Yaesu Quadra. I use DDutil to provide band data to the amplifier wih no problems.
Paul W5PF0 -
Larry,
Here is a document I wrote on doing what you are asking.
https://dl.dropboxusercontent.com/u/20979885/Quadra%20to%20a%20Flex%206500.pdf
Jon...kf2e1 -
Hi Larry,
If you follow Jon - kf2e post, all will be good. I have done the same and works great. Any Questions just give me a shout and I'm sure Jon will help also.
Larry - ke2yc
I use DDUtil with an FL-7000, setup using the kf2e post, and it works great. I have my laptop in a dock, which has s parallel port. Larry, W1IZZ0
Hi Larry,
I ordered the ACC USB-Serial cable from Flex Radio Store to interface my 6500 to the QUADRA VL-1000 Amplifier, but need to wire it to the 8 pin din connector. Your pdf file is no longer available. Has there been an update?
Bill, NE1B
You can wire the 4 band wires plus ground by the din picture in the Quadra manual but be sure you have the newer manual as there was a pin number mistake in the old manual. Setup is in the radio usb tab. No third party program needed.0
I would be interested in thispdf file as well.... I also plan to interface my flex with the 6600. I have used a Flex 5000 and Quadra together with DDutil for the past 8 years... but would be interested into see your Document Jon.0
Hi John,
Which cable did you use? Was it a mouser cable or Flex cable? Is there a part #?
Bill
An Amazon cable FTDI C232HM-DDHSL-0, that was linked in another thread. Plugs into the back of the radio and wired to the din plug on the amp.0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
