Flex 6700 and WSJT-X no decode on all bands
2»
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    edited February 2018
    Regardless of WSJT-X, the waterfall on flex should not look like that.  The signals should be almost 15 seconds long and without the curve. See my waterfall for comparison.
    You can leave the DAX out of it. Because garbage in is garbage out. That is not right.
  • Marc Lalonde
    Marc Lalonde Member ✭✭
    this is how must look the 10.000Mhz   WWV   signal whit panadapter zoomed to maximum
    straight whit absolute no deviation ...
  • Don, VE2HJ
    Don, VE2HJ Member ✭✭
    edited June 2019
    Tanks Torsten for the picture.
    Now the question is : is the problem from the radio or from the antennas ?
    Do you have any other means to see and decode the signal received from the antenna ?
    de VE2HJ
  • John Culliton
    John Culliton Member
    There is no slice audio in his rx streams. That is where the audio is to be picked up by wsjt-x. If he has a frequency stability issue this bad he should hear it in voice and cw, it should be obvious.
  • George KF2T
    George KF2T Member ✭✭✭
    edited April 2020
    Suggestion: Perform a factory reset on the Flex, including physically removing it from power for a minute or two. Restart your computer and run ONLY Flex apps (SSDR, CAT, DAX). Does the SSDR waterfall change in any way?
  • Chris DL5NAM
    Chris DL5NAM Member ✭✭✭
    George your right -i am sure , it's the best he can do
  • Torsten
    Torsten Member
    edited February 2020
    @Marc Lalonde
    please that what you mean?image
  • Marc Lalonde
    HI Torsten  ,if signal "wave" on bandscope like this ,radio drifting off frequency
    think time to open support ticket , i surprise Tim not already do ?
    few HZ drift is not to big for **** SSB   ,but Digital signal for sure
    check external 10mhz reference if you have one , if not radio have probably hardware issue
    if you have last version of smart SDR look in radio setup
     make sure it locked
  • Torsten
    Torsten Member
    OK i have a picture from the drifting 10MHz Signal. Thats crazy, it is drifting from left to right...
    I test the hardware reset, than i think it is time to take a ticket.image
  • Rich McCabe
    Yep, contact Flex.  I am sure they will get you fixed up.
  • WF7B
    WF7B Member
    Yep that's a sick radio.
  • Marc Lalonde
    whoop  something wrong for sure now ...
  • Torsten
    Torsten Member
    @Marc Lalonde
    i have no external GPSDO
    Yes i see in the slice
    @John
    thanks, yes i know but this works. Audio is OK
    @ all
    i have make the hardware reset, i think it is time
    for my third ticket
  • Marc Lalonde
    put last image whit ticket ,it wort 1000 word
  • Don, VE2HJ
    Maibe you should upgrade to the last SSDR v2.1.30 and redo the 10Mhz test.
  • Torsten
    Torsten Member
    @Donald
    i use v.2.1.30
  • Don, VE2HJ
    Ho , i thought it was 2.0.19 at the beguinning of the post. Sorry.
    Good luck .
  • Tim - W4TME
    This has been determined to be a hardware issue that is being addressed via the HelpDesk
