Flex 6700 and WSJT-X no decode on all bands
Regardless of WSJT-X, the waterfall on flex should not look like that. The signals should be almost 15 seconds long and without the curve. See my waterfall for comparison.
You can leave the DAX out of it. Because garbage in is garbage out. That is not right.
this is how must look the 10.000Mhz WWV signal whit panadapter zoomed to maximum
straight whit absolute no deviation ...
Tanks Torsten for the picture.
Now the question is : is the problem from the radio or from the antennas ?
Do you have any other means to see and decode the signal received from the antenna ?
de VE2HJ
There is no slice audio in his rx streams. That is where the audio is to be picked up by wsjt-x. If he has a frequency stability issue this bad he should hear it in voice and cw, it should be obvious.0
Suggestion: Perform a factory reset on the Flex, including physically removing it from power for a minute or two. Restart your computer and run ONLY Flex apps (SSDR, CAT, DAX). Does the SSDR waterfall change in any way?0
George your right -i am sure , it's the best he can do
HI Torsten ,if signal "wave" on bandscope like this ,radio drifting off frequency
think time to open support ticket , i surprise Tim not already do ?
few HZ drift is not to big for **** SSB ,but Digital signal for sure
check external 10mhz reference if you have one , if not radio have probably hardware issue
if you have last version of smart SDR look in radio setup
make sure it locked
OK i have a picture from the drifting 10MHz Signal. Thats crazy, it is drifting from left to right...
I test the hardware reset, than i think it is time to take a ticket.
Yep, contact Flex. I am sure they will get you fixed up.
Yep that's a sick radio.0
whoop something wrong for sure now ...
put last image whit ticket ,it wort 1000 word0
Maibe you should upgrade to the last SSDR v2.1.30 and redo the 10Mhz test.0
Ho , i thought it was 2.0.19 at the beguinning of the post. Sorry.
Good luck .
This has been determined to be a hardware issue that is being addressed via the HelpDesk1
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
- 918 Genius Products
