Please Fix Iambic A Keying Mode
Jerry Gardner
Please fix Iambic A mode so that it works like it should. I discovered it's broken when my Winkeyer developed a problem and I had to switch to the Flex built-in keyer.
There are three iambic modes: basic, iambic A (Curtis), and iambic B (Accu-Keyer). The difference between them is how dot/dash memory is implemented. Basic iambic doesn't have dot or dash memory. Iambic A has dot, but not dash memory, and iambic B has both dot and dash memory. The SmartSDR implementation of Iambic A is really basic iambic with neither dot nor dash memory.
Here's how to tell the difference: set the internal keyer to its slowest speed (5 WPM). Send a "N" as fast as possible (quick tap of right paddle followed quickly by a tap of left paddle while still holding the right paddle, and then let go of the right paddle before the dah is finished). In true iambic A, this should result in the keyer generating an N. In the SmartSDR implementation it generates a T because it doesn't properly implement dot memory.
Now try sending an "A" quickly by quickly tapping the left paddle followed by quickly tapping the right paddle while still holding the left paddle, then quickly release both. In iambic A this will result in the keyer generating an E (because there's no dash memory). In Iambic B the keyer generates an "A".
2
I have never heard your description of iambic A & B.
My understanding:
Mode A (also known as original Curtis) has no memory, dot or dash.
Mode B has memory for both.
It is further explained in this 3rd party document:
http://www.palm-radio.de/pdf/IambicPaddleModeAorBfunction-1.pdf
K8RC0 -
See the app note for the Curtis 8044--it distinctly mentions memory.
http://users.ox.ac.uk/~malcolm/radio/8044print.pdf
As it was written by John Curtis himself, the designer of the 8043 and 8044, and the one who coined the terms Iambic A and Iambic B, I'd consider it definitive over any other reference, including the one you posted,0 -
Have YOU read John Curtis' explanation? It agrees with the document I posted.
Read it again, sir.
Yes, I've read it. He talks about dot/dash memory in this paragraph:
"Dot memory is absolutely essential in any serious electronic keyer. Dot memory allows a keyer to remember that you hit the dot key even though you hit the key early and did not wait for the dot to commence. Send a fast “N” on any keyer to test this feature. You cannot hit the dot and dash key fast enough to prevent both transmitting. If you do not have dot memory, the dot will be lost in most cases."
The Flex Iambic mode A does not implement either dot or dash memory, and hence loses the dot when sending an "N".
I have a keyer here based on the Curtis 8043 and I just tried it--it implements dot memory, but not dash memory.
The WinKeyer implements Iambic A with a slight variant on the Curtis method--it implements dot memory and partial dash memory.0 -
The part you're quoting from that document are AFTER the introduction of Type B. The last sentence of the section you just quoted IS:
"For true iambic operation, both dot and dash memories are required for reliable dot or dash insertion."
WHICH IS TYPE B!!!
So put it on type B if you need help with your dits.
-sk-
That's not the point. The point is that the definitive reference for correct type A behavior is the Curtis IC, and SmartSDR doesn't implement it correctly.0
Jerry,
Did you ever get movement on this with Flex. I'm a new Flex user (6400) and new to CW. I thought it was my cheap MFJ paddle, but you described the issue I'm having exactly.
Is there a solution w/Flex? Or is an external keyer a solution?0 -
This is still an issue. I saw the problem first with the key I made from a kit. I thought it was a poor dit contact since I haven’t used it for many years. I cleaned and realigned the contacts but still have the missing dit as described in the first post of this thread almost three years ago. Still thinking it was the key, I borrowed a Bencher and found the same problem. Using these same keys on my old K1, the problem doesn’t occur. I appears that in 3 years the keyer function has not been corrected.
73 Steve KD2OM
My 6600M works the same way as every iambic keyer I’ve ever had: to send a “C” in mode A, release the paddles after the second dit. In mode B, after the second dah.
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 115 Aurora
- 980 Genius Products
- 359 Tuner Genius XL
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
- 486 Remote Operation (SmartLink)
- 848 Peripherals & Station Integration
