Pop up Window Problem in SmartSDR 2.1.30
Stewart Lewis
I am using SmartSDR 2.1.30 with a Flex 6700. When I open a popup window on the panadaptor, I get a white box with 3 options – Tune Guides, Create Slice, and Create TNF. They are also white. If I move the mouse pointer to any one of the options, letters of that item turn black on a dark blue background. I can’t see the letters well enough to read them. Is there a setting I need to change in order to make them white?
73, W0SHL
Without any parameter changes (that I know of), I get a black box with print and very easy to read.
A total guess, but do you use a non-standard windows theme? Maybe it is picking something up from that.0
No special windows theme here. I also moved the SmartDR screen to my other 2 monitors. Same problem!
I cannot duplicate the behavior described. Have you made any other changes to the display different than the defaults?0
No changes! Maybe I need to re-install 2.1.30???
I doubt a reinstall would make a difference. Can you post a screen capture of what you are describing?0
Tried a few times...and I get a very readable print....
Attached are 2 pictures showing the problem!
This looks to be something local to your PC. When I mouse over the line the background shading highlights and the text color and intensity stays the same.
What is interesting is I do not see your mouse pointer in the area highlighting the 2nd line0
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
