Pop up Window Problem in SmartSDR 2.1.30
Stewart Lewis
Stewart Lewis Member ✭✭
I am using SmartSDR 2.1.30 with a Flex 6700.  When I open a popup window on the panadaptor, I get a white box with 3 options – Tune Guides, Create Slice, and Create TNF.  They are also white.  If I move the mouse pointer to any one of the options, letters of that item turn black on a dark blue background.  I can’t see the letters well enough to read them.  Is there a setting I need to change in order to make them white?
73, W0SHL
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited February 2018
    Without any parameter changes (that I know of), I get a black box with print and very easy to read.
  • Paul Lourd
    Paul Lourd Member ✭✭
    edited May 2020
    A total guess, but do you use a non-standard windows theme? Maybe it is picking something up from that.
  • Stewart Lewis
    No special windows theme here.  I also moved the SmartDR screen to my other 2 monitors.  Same problem!
    I cannot duplicate the behavior described.  Have you made any other changes to the display different than the defaults?
  • Stewart Lewis
    No changes!  Maybe I need to re-install 2.1.30???
    I doubt a reinstall would make a difference.  Can you post a screen capture of what you are describing?
  • N2TU
    N2TU Company Adviser ✭✭
    edited March 2018
    Tried a few times...and I get a very readable print....
  • Stewart Lewis
    Attached are 2 pictures showing the problem!image
    This looks to be something local to your PC.  When I mouse over the line the background shading highlights and the text color and intensity stays the same.
    What is interesting is I do not see your mouse pointer in the area highlighting the 2nd line
