Maestro loses wifi after upgrade to latest software
W3EX -- Tom
After upgrading to the latest software, my Maestro will no longer see my wifi access points. The Ethernet connection works fine; but no wifi. I tried Dudley's suggestions but to no avail. Has anyone else experienced this problem?
This has been a problem for a long time. If you look back in the archives of this site you will find a lot of users complaining about this. For myself I don't use wifi on my Maestro. When I do I will get chopped audio, inconsistent panadapter function. After about fifteen minutes the Maestro quits.
When all of this is taking place, the Maestro is sitting about 2 feet from the wifi source.0 -
Just a observation I have here on my WiFi, If I try to connect with 5.8G it connects but won't find the radio, If I connect to the 2.4G it finds the radio just fine and works as expected.
HOWEVER, 5.8G will connect using SmartLink even though it is all on the same router.
I have gone through my router settings to see if there is a setting that keeps the wired and wireless network separated but don't see why 5G is different the 2.4G.
73's
Bret
WX7Y
I have found with my router the 5ghz is of course much faster but the range is much less and of course with this less dependable. I just stick with 2ghz in this case and seems to solve my problems
Before I upgraded the wifi connection was working quite well. Now it is totally dead. I am going to be traveling to a house where there is just wifi and no Ethernet direct plug in. Hopefully I can get it fixed by then.
Hi Tom Sorry about your problem. I wish I could help with a fix. Just a suggestion, if you can’t get it fixed before you leave for the other home, downgrade to the previous version of smartsdr. That way you can have fun while your there and when you get back hopefully they will have a fix. Have fun. Larry ke2yc0
Actually thought of that, in fact Dudley had me take it back to a previous version. Still no wifi but thanks for the thought.
So what’s the root cause? How common is this issue? When will it be fixed?0
I don't know yet. I have tried everything that Dudley has sent me and it is still failing. The upgrade to the latest software seems to be what broke it. But going back to the previous version did not fix it. Very frustrating.0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
