SmartSDR-IOS update Version 2.3 is here !
Chris DL5NAM
Member ✭✭✭
SmartSDR-IOS V2.3 is ready for download at Apple App store.
Thanks to Marcus DL8MRE !
Hey, why you not let some "stars" and a comment about this software at APP store?
Marcus did a great job, do a good support and has a "open ear" for our feature requests!
73 Chris
DL5NAM
73 Chris
DL5NAM
6
TU, very nice.0
I really like the color intensity panadapter fill. Excellent idea Marcus!0
Yes, and that in combination with the spotted calls (DX cluster option) shows very useful.
Have Marcus asked to have also a "peak hold" function in scope window - cross my fingers. I don't know is t possible.
Chris0 -
Nice work Marcus. Love the app.0
Just wrote a review for the APP Store... still the best app in the store1
Btw I believe TMobile smartlink users may be good to go now. There is an IPv6 option in the settings which enables IPv6.0
well it use to work on my ipad 2 running ios 9.5.3 apple no longer provides ios updates for this ipad2
and
now not able to download the updates to smartsdr
and
smartsdr wont run cause it wants the latest data updates ;-(
might be good idea to identify list of ios products it now currently run on
i do have ipad pro and iphone 8 where it runs perfectly
Paul K3SF
In the App Store it says that it requires iOS 10.0 or later.
You beat me to it :-)
hi guys
true App store does say ios 10 BUT I have been running it on ipad 2 with ios 9.5 and it still runs BUT when i go to update data is says update data from app store BUT wont update data from app store. just trying to understand if it really necessary to update data and what impact it may have on version i am currently running on the ipad2
i am running against the demo cause i am waiting for my 6600m to arrive it did work ruuning my 6300 but that was over 8 months ago when i sent it in as part of the trade-in program...
even if i can not run the panafall i would like to still use it a a control surface
just trying to understand what are the issues being left behind...
note the ipad 2 can not be updated to ios10 even though it has the compute power to do handle it ;-((
here are recent screen captures from the ipad2
Paul K3SF
I think the pragmatic answer is since you are using the older version of the app it will work with your radio until it doesn't.0
hey tim
i agree...
i was just just hoping that chris may be able to provide some insight as to when that may be.
BUT
The real question is can the older app run fine use older data on older ios with the current flex radios running current ssdr?
i havent be able to test as no flex here currently to try it. i do know my 6600m should be shipping soon so i can test it live.
Like i said before i do have ipad pro and iphone 8 each running latest ios
and no issues there...latest app, latest app data..
paul K3SF
we don't do reverse regression testing.
If you are getting a 6600, it will not work with that version of the iOS app. The radio must run SmartSDR v2.1.30 or greater and version 2.1.30 is only supported with version 2.3.0 of the iOS app.1 -
From the manual:
In addition to App updates, I am providing so called Data-Updates. Such Data-Updates can be used to update certain databases of the App such as the DX-Cluster Server database or Bandmap.This way, I can provide updates easier and quicker without the long lasting AppStore release process.Once there is an update available, normally, you will get notified and can install a Data-Update straight away. However, my App will only check for Data-Updates once per day and only if you are connected via WiFi to prevent wasting your data plan.For this reason, please check from time to time, if there is a Data-Update available by hitting the Check for Data Update button.
So it looks like you can just ignore the update if your iOS device doesn't support the update.
If it keeps nagging you, you may want to send a note to Marcus and see what he can do, but iOS apps are not really friendly to downgrading.
As an iOS developer myself - I feel the pain of having to support older devices, not because they are old but because occasionally Apple just blows that up when they force you to use certain minimum versions for App Store submission and also certain features are only available in later versions and the code is not backwards compatible.0 -
I have been running SmartSDR for iOS on the T-Mobile network for three days. and all functions are supported. However, you must be running iOS 11.2.5 and SmartSDSR for iOS 2.3.0. You must also enable the IPv6 option in SmartSDT for IOS0
I do not see any option to do the update. I have version 2.2.2. If I tap check for data updates in the app it says "data update available". When I go to the app store there is the app does not show and I have no option to update it. How do I resolve this??
Harry
W0LS0 -
If you are not on iOS 10 and above no update is available.0
Hi Ria...ios settings says I am at 11.2.1. I am updating now to 11.2.5...
Harry0 -
Problem...after I updated the ios from 11.2.1 to 11.2.5 the update option was displayed and all is well.
Thanks.....
Harry
W0LS0
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
