RTTY Skimmer Server setup (again)
Frustration set in and I uninstalled everything and eventually even lost my working RTTY Skimmer Server config files. I'm pretty sure I can reconstruct them though as I went through enough pain to get them working in the first place that I probably remember enough of the details.
But, the trouble I'm having is getting RTTY Skimmer Server to even recognize the 6700 at all. Using the skimmer/sdr command only lists the QuickSilver device where I was expecting to also see the 6700. I do remember having to copy some files from the SDR-Bridge install to RttySkimServ directory to get things going last time. I even found a couple of posts talking about that but they seem to be out of date.
Is there an installation procedure for all of this that I've missed? At this point I have the most recent version of SmartSDR, SDR-Bridge, RTTY Skimmer Server, and CW Skimmer Server (also not working), and CW Skimmer all installed. Suggestions would be much appriciated!
I will be attempting to setup RTTY Skimmer Server with SDR Bridge and SmartSDR V2 this evening, so will feedback my experiences. I have CW Skimmer working Ok ish.0
I couldnt get it working, so would be keen to hear your feedback
At this point I can run CW Skimmer with SDR-Bridge. But RTTY Skimmer Server and Skimmer Server are still having trouble. Launch either one and connect via telnet and issue the 'skimmer/sdr' command and '01 SDR-Bridge v1.5.1' will show as an option and they can now control the panadapters.
To get to this point, it's important to install SDR-Bridge after installing the skimmer servers. The installer for SDR-Bridge writes files to the RttySkimServ and SkimSrv install directories. These files are needed by the servers to communicate with the radio. Do it in the wrong order and the needed files wont be available.
Now, I seem to be bumping into a different problem. RTTY Skimmer Server isnt able to open the I/Q device. In the DAX display the channels usually show as 'in use by another computer'. Sadly it doesnt say which other computer. There are a few threads here talking about this but folks seem satisfied when told to take the message literally and look for another computer that has a stream open. In my case I dont. Further, this doesnt seem to get in the way of CW Skimmer using the I/Q stream when launched from SDR-Bridge.
Back when everything was working I'd occasionally get into a state where jiggling the panadapter or toggling the stream number in the DAX interface was necessary to get things in sync. So far, none of that helps.
...so, some progress at least.1 -
I am in exactly the same situation as you described above. Shame as I was hoping to use this weekend.
One observation if the IQ Streams in Dax are selected and Yellow with the Busy and in use by another computer. If I terminate RTTY server then they turn blue and say streaming. I had read in another post they should be greyed out suggesting the rtty server doesn't use DAX to access the IQ streams.
Also setting DeviceName in the ini file to 01 or 02 doesn't seem to change the rtty server behaviour.
By any chance are you trying to connect things via SmartLink? If so DAX (and thus Skimmer) will not currently work via SmartLink connection. If using your radios locally using version 2.0 then do not use Smartlink to connect. Use a normal SSDR conection and your interconnecting programs you used with DAX should be fine.
When running SmartSDR for windows on the LAN there is no option to select a smartlink or non smartlink connection like there is on Smart SDR for iOS. CW Skimmer works fine so the IQ streams are working.0
Smartlink is not being used... just a regular LAN connection to the radio.0
I agree.0
Does anybody at flex know if anything has changed in V2.0 that would prevent RTTY Skimmer working.
Rather than me continue investing time in trying to get it working.
...or can anyone in the community confirm that either Skimmer Server or RTTY Skimmer Server runs with v2.0? With just a little encouragement I'll keep working at it, but right now I'm running out of ideas.0
... did any try the free DL4RCK RTTY Skimmer ? Walter is also a Flex'er and author of RCK-RTTY and RCK-Log
http://www.sites.google.com/site/rckskimmer/
Thanks, I will test that today.
.....After testing
It supports PowerSDR and OmniRig but not SmartSDR Dax IQ
I have sent an email to Alex the author of RTTY Skimmer.
I am now going to concentrate on getting N1MM Spectrum display optimised with the RBN and try to filter to meaningful spots.
I will try and get back to the RTTY Skimmer after this weekend RTTY contest. I am surprised there aren't more flex owners on the forum doing the data contests and looking to use tools like RTTY skimmer.
Shame we haven't had any input from flex as I know there was some revisions to the N1MM spectrum Monitor that uses IQ after V2 SW was released. The requirement for these changes may affect all SW that uses IQ streams.
I do have same situation here. It is the first time since the WPX RTTY I power up RTTY Skimmer again. It seems to connect to my Flex (the Flex bands follow the RTTY Skimmer configuration) with SmartSDR 2.0.19 but it looks as if the Skimmer DLL from SDR-Bridge does not decode anything. The bandscope remains fully empty and therefore no decoded call signs.
SDR is recognized as 4x96 khz but the band scope can be used from RX0 to RX7. I do not recall if it was the same behaviour last time.
Skimmer Server and RTTY Skimmer Server connect but do not decode with either SmartSDR v1.11.12 or v2.0.17. They do work with v1.10.16. I am looking into a fix. In the mean time I suggest using the working version.
73 Ed W2RF
Thank you for the confirmation.1
ED: Where does this stand...? Using SmartSDR v 2.0.19, any joy?
any progress or workarounds?0
Ed's latest beta
http://www.qrv.com/download/SDR-Bridge_v1.6.4_beta_Setup.exe
has been working great for me with both SkimmerServer and RTTYSkimmerServer.
anything special to get it working with RTTYSkimmer, like copying .dll's around as i seen in various discussions...tks0
Just install SDR Bridge after you install the RTTYSkimmer server. It copies at least one file into RTTYSkimmer server's install directory. Make sure you have a couple of panadapters visible with the higher numbered daxiq channels assigned to them. You might have to go into DAX and toggle the DAXIQ channels on/off... but I dont remember if RTTYSkimmerServer wants them on or off. SkimmerServer wants them off.
But.. if you've never used RTTYSkimmerServer before, you'll have to dig into how it's config file works. It's a bit tricky.1 -
...thanks, sounds like fun times ahead as its my first go at RTTYSkimmer...0
Anything new on this or is it still rather tricky to get RTTY Skimmer Server to work ?
Andy K3UK
Andy,
You might want to look at the SDC skimmer server from Yuri (UT4LW). It was originally targeted at Expert Electronics SDR kit using their TCI interface. After the Russian invasion of the Ukraine, Yuri rewrote it for SmartSDR. It uses the API to get an I/Q stream so you don't need to mess around with DAX IQ at all. As well as RTTY, it supports PSK and CW.
The software is free / donation-ware but needs a product key which Yuri provides in response to an email.
Development seems paused at the moment but then Yuri is working from a war zone!
73 Martin
Martin is correct. SDC skimmer works fine for both CW and RTTY without any "helper" programs (bridges, etc)
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
