Setting up CW keying speeds in Flex 3000 KE9NS latest revision
Jean-Philippe DIEL
I am having a bit of trouble setting up CW speed and iambic keying in the Flex 3000 with KE9NS revision.
Is there a way to change the length of a dot and dash ?
Thanks in advance. ZL1RPL 73's
Fixed and posted separately my findings. In fact disabling VAC2 which was linked to Microsoft Soundmapper fixed that issue. I initially thought the weights were wrong and was looking for some sort of configuration menu but in fact VAC was adding latency and causing the iambic Key sidetone to respond erratically. The only thing I am having to do now is use headphones on CE instead of the computer speakers... a small trade off. Cheers0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
