Setting up CW keying speeds in Flex 3000 KE9NS latest revision
Jean-Philippe DIEL
I am having a bit of trouble setting up CW speed and iambic keying in the Flex 3000 with KE9NS revision.
Is there a way to change the length of a dot and dash ?
Thanks in advance. ZL1RPL 73's
Fixed and posted separately my findings. In fact disabling VAC2 which was linked to Microsoft Soundmapper fixed that issue. I initially thought the weights were wrong and was looking for some sort of configuration menu but in fact VAC was adding latency and causing the iambic Key sidetone to respond erratically. The only thing I am having to do now is use headphones on CE instead of the computer speakers... a small trade off. Cheers0
