Meters on Maestro
[Deleted User]
edited December 2017 in SmartSDR for Windows
I noticed you can bring up several meters on the Maestro by pressing "meters". Can this be done in Smart SDR on the PC
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    No, but soon Flex will be including a meter maid, to make it easier.
  • Tim - W4TME
    This is a feature of Maestro due to limited screen real estate.  In SmartSDR you can show all these meters at the same time.
  • Garry F. Fisher
    Where on the Maestro do you find the meters  (Maestro by pressing "meters")
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    Gary,  Bottom right hand corner of the Maestro display when connected to the radio..
  • Garry F. Fisher
    Thanks I will Look for this!
    Garry
  • w9sss
    w9sss Member ✭✭
    [{"insert":"I'm operating remote with my maestro but apparently it does not show date/ time ??\n"}]
  • ka9ees
    ka9ees Member ✭✭✭
    @w9sss
    It does not nor does either of the M models. If you run remote from an iPad or a PC then you'll have a clock.
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    If you have the GPSDO installed in your M model, you get UTC in the GPS tab of the main menu. Or, you can buy a $3 battery-powered clock.
