Maestro Storage
Doug - W3UB
What is the best recommendation for storing the Maestro for a few months?
Where I am located, the power is guaranteed to be off a few times this winter. If you leave the unit plugged in, every time the power comes back on, it boots up!
And then stays that was for the duration. No screen saver or power down!
If you leave it unplugged, you run the risk of the internal battery running down and rendering the unit inoperable.
Considering this issue, it seems like some sort of auto-power down upon some idle time period would be a very good idea.
/Doug
/Doug
2
I'd be interested in knowing about long term storage as well.
Having the unit power up when plugged in is bothersome. My Maestro cycles on every time we get a short power outage, and if I don't notice it my Maestro might be on for days. If possible, I'd like to see FRS fix this.
The screen used in the Maestro is not susceptible to display burn-in. Leaving it powered on for long durations is OK. The Maestro I use for support and testing stays on 7x24x365 and I use one of the first ones ever manufactured. I leave it powered by the AC power adapter and use the battery only when needing to test use cases that require mobility.2
Understand the FRS position, but I as a customer disagree with the idea of leaving it on long term, or having it turn itself on after a power event. There are multiple layers of design issues here, and they could be mitigated by a FW change to at least power down if not used.
Devices should not power on by themselves in this manner, nor should they be at risk of having an inaccessible battery discharge if left unpowered.
Just my two cents.
/Doug
Doug, If it is a major concern get a small UPS to power the Maestro and it will not see the power failures and thus turn on. Just my 2 cents.
73, Dennis W4SG
- 368 Community Topics
- 625 The Flea Market
- 8.1K Software
- 74 SmartSDR+
- 421 SmartSDR for Mac
- 270 SmartSDR for iOS
- 189 DAX
- 33 Aurora
- 238 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 913 Genius Products
- 331 Tuner Genius XL
- 122 Antenna Genius
- 293 Shack Infrastructure
- 449 Remote Operation (SmartLink)
- 773 Peripherals & Station Integration
- 991 Third-Party Software
