ftdi cable for connecting a steppir controller to a Flex 6700
KB4HL
Hello can anyone give me a lead to order the correct FTDI cable for connecting the stepper controller to the usb port on a Flex 6700. Any help would be greatly appreciated.
Harry
AH6FF/W3
Harry
AH6FF/W3
This:
http://cart.flexradio.com/USB-to-Serial-adapter-for-the-FLEX-6000-series_p_1002.html
Or this, which is the same thing but from Digi-Key:
https://www.digikey.com/product-detail/en/ftdi-future-technology-devices-international-ltd/UT232R-50...
Must be genuine FTDI.0 -
Ok Ria thank you so much and I also am going to connect an SPE 1kw amp .
Thanks so Much
Caution - a lot of them are counterfeit on Amazon.
If that one definitely works in your own experience then it is good. Otherwise, not. FTDI had put out a driver update a few years ago that disabled the fakes.0 -
It's not, I have two working on the Flex as we speak. On for the SteppIR and one for the SPE amp, but then again I suffer from delusions of adequacy so...0
Want to add to this thread as I am in the process of doing this. Dont forget to get a gender changer. The above links are male serial connections and so is the SteppIR. So wont mate up without additional hardware
Rich
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
