Two Instances of WSJTX Different Slices
Andrew O'Brien
Member ✭✭✭
Has the process for doing this changed since the thread that addressed the issues a couple of years ago.
I am interested in doing it with JT Alerts and DX Lab Commander
Andy K3UK
Andy K3UK
Not sure which thread you're referring to.
The way I do it is to set up each slice with a different DAX and CAT , and for each instance of WSJT-X you should add a command line parameter ( --rig-name=<name>) for that instance. It will create two separate directories with log files and such.1 -
Thanks, that is how I have done it previously. I'm not sure what you mean by "IT will create two separate directories ".
Andy0 -
If you have two different instance names, the app data files are stored each in their own directory.0
Thanks Ria!!0
FYI, using Commander for PTT so can log to DX Keeper1
I spoke too soon. Using Commander, eventually A follows B and both instances end up on same frequency.0
I just set up WSJT-X with its own CAT port0
Yes, I will probably do same.0
I have two instances now set via two TCP ports in SmartCAT and work well. How are you logging? Log to a third party logging application of just WSJTX's log and then ADIF import to logging software ?
Andy K3UK0 -
As usual, Ria's instructions are perfect.
I'm not gonna lie, having 20M and 40M WSJT-X FT8 going simultaneously is a treat. Combined with JT-Bridge to integrate across OS to MacLoggerDX, with the ability to click on any desired CQ and have the radio and transmit slice follow automatically....
MAGIC!!!! :-)1 -
Ria
Can you post an example of running several instances of WSJT.
thanks Don - kx9q0
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
- 918 Genius Products
