Two Instances of WSJTX Different Slices
Andrew O'Brien
Andrew O'Brien Member ✭✭✭
edited January 2020 in FLEX-6000 Signature Series
Has the process for doing this changed since the thread that addressed the issues a couple of years ago.
I am interested in doing it with JT Alerts and DX Lab Commander
Andy K3UK
  • Ria
    Ria Member ✭✭✭
    edited January 2020
    Not sure which thread you're referring to.
    The way I do it is to set up each slice with a different DAX and CAT , and for each instance of WSJT-X you should add a command line parameter ( --rig-name=<name>)  for that instance. It will create two separate directories with log files and such.
  • Andrew O'Brien
    edited November 2019
    Thanks, that is how I have done it previously.   I'm not sure what you mean by "IT will create two separate directories ".
    Andy
  • Ria
    Ria Member ✭✭✭
    edited December 2017
    If you have two different instance names, the app data files are stored each in their own directory.
  • Andrew O'Brien
  • Andrew O'Brien
    Thanks Ria!!
  • Andrew O'Brien
    FYI, using Commander for PTT so can log to DX Keeper
  • Andrew O'Brien
    I spoke too soon.  Using Commander, eventually A follows B and both instances end up on same frequency.
  • Ria
    Ria Member ✭✭✭
    I just set up WSJT-X with its own CAT port
  • Andrew O'Brien
    Yes, I will probably do same.
  • Andrew O'Brien
    I have two instances now set via two TCP ports in SmartCAT and work well.  How are you logging?  Log to a third party logging application of just WSJTX's log and then ADIF import to logging software ?
    Andy K3UK
  • Justin W4JTD
    Justin W4JTD Member ✭✭
    As usual, Ria's instructions are perfect.
    I'm not gonna lie, having 20M and 40M WSJT-X FT8 going simultaneously is a treat. Combined with JT-Bridge to integrate across OS to MacLoggerDX, with the ability to click on any desired CQ and have the radio and transmit slice follow automatically....
    MAGIC!!!! :-)
  • DonS
    DonS Member ✭✭✭
    edited July 2018
    Ria
    Can you post an example of running several instances of WSJT.
    thanks Don - kx9q
