Sidetone ?
Andrew O'Brien
Andrew O'Brien Member ✭✭✭
Not sure what happened but i get no sidetone when using a key .  Volume slider is all the way up.
Andy K3UK
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    Andy,
    Sorry if this is too obvious but is the sidetone button to the left of the volume slider clicked and illuminated? Let me know if this works and if not we can try something else.
    Mack
    W4ax
    Alpha Team
  • Jim K4JAF
    Jim K4JAF Member ✭✭
    edited January 2018
    Is the sidetone caption checked and turned blue?
  • Unknown
    Unknown Inactive Employee
    edited December 2017
    Make sure you have your master volume turned up,  speaker or headset depending on your usage.
  • Andrew O'Brien
    Got it figured out , all settings were correct but the speaker cable had an issue.  Thanks
    Andy K3UK
