Sidetone ?
Andrew O'Brien
Member ✭✭✭
Not sure what happened but i get no sidetone when using a key . Volume slider is all the way up.
Andy K3UK
Andy K3UK
Andy,
Sorry if this is too obvious but is the sidetone button to the left of the volume slider clicked and illuminated? Let me know if this works and if not we can try something else.
Mack
W4ax
Alpha Team0 -
Is the sidetone caption checked and turned blue?0
Make sure you have your master volume turned up, speaker or headset depending on your usage.1
Got it figured out , all settings were correct but the speaker cable had an issue. Thanks
Andy K3UK0
