Anyone try to use a PW-1 on aFlex? When I get my 6600M would be nice if I new it would work on it.
Brad
Icom PW-1 working on 6600M
I've used a PW-1 on my Flex-6700, no problem at all, although I suggest using the the DDUtil program to preset the drive levels on each band.
Years ago I had a PW-1 with various Flex Use DDUTIL to control the connection and see DDUTIL site for deatails Works seamlessly with a Flex0
Had a FT-1200 hook up to it, the only thing didn't like was it did not band switch auto. I only drive with 45 watt and still get 900+. It will handle 100 watt drive. Will look at the DDUTIL. If I remember the 1200 was hook to the ALC and PTT. Looking for the 6600 as am down to IC-7100 now. Thanks All Brad
With DDUTIL it will automatically band switch0
I'm very happy you've had no problems with your PW-1 and your 6700. We finally gave up after trying to make the CI-V interface work and the unending issues of it working and then not working and trying to figure out what happened. We used DDUtil as well.
I offer a module called the W2PH AutoBandSwitch that allows any Flex 6xxx to control a PW1. It even supports pass through features. It does not use the Flex's CIV at all freeing it up for logging or other software. ed@w2ph0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
