n1mm function key CW speed
Bob Kupps
Hi I am using a 6700 with SDR v1.7.30 and Maestro v1.10.16.25. Changing the speed control in N1MM changes the Flex keyer speed but does not change the speed at which the F# message is sent. The N1MM gurus suggest that it is a winkey emulation issue. Any suggestions? TU 73 Bob HS0ZIA
By F# do you mean the SSDR F# or the N1MM F# ? I haven’t noticed this.0
Hi Matt I mean the CW messages sent by the N1MM function keys.0
what do you have set in the winkey tab here?
Also, Is you key plugged directly into maestro or into the flex transceiver? we should be able to nail this down.0
Hi Chris I do not have an external winkeyer just paddles that are plugged into the 6700. It does not make any difference which box I have checked. I set up the winkey com 6 per a video on youtube so maybe I don't need com 6 at all? TU for any help Bob HS0ZIA
PS **** question but I assume the Maestro software version is what is controlling, not the smart SDR version on the PC?0 -
After updating the PC SDR to the same version as the Maestro the problem was solved. TU 730
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
