Software version
Bob,
It makes zero difference what version is on your computer unless perhaps you are running your computer for DAX and CAT to control other things such as logging.
In this case you should probably run the latest version of CAT and DAX on your computer to make sure you have the latest code and compatibility.
I download new software to my computer at least weekly and just make a habit of keeping the versions the same.
Mack
W4AX
Alpha Team1 -
Thanks Mack. I am having a problem with N1MM logger winkey so will download the same version onto the PC. Bob HS0ZIA0
After updating the PC SDR to the same version the N1MM problem was solved! TU1
Bob,
You're very welcome. I always recommend running the latest version of the software. On the Alpha team we work hard to find bugs before the software is released and the Flex developers to a great job of listening and fixing things.
Merry Christmas,
Mack
W4AX0
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
