n1mm function key CW speed
Bob Kupps
Bob Kupps Member
edited October 2018 in FLEX-6000 Signature Series
Hi I am using a 6700 with SDR v1.7.30 and Maestro v1.10.16.25. Changing the speed control in N1MM changes the Flex keyer speed but does not change the speed at which the F# message is sent. The N1MM gurus suggest that it is a winkey emulation issue. Any suggestions? TU 73 Bob HS0ZIA
  • Matt (K0KB)
    Matt (K0KB) Member ✭✭
    edited October 2018
    By F# do you mean the SSDR F# or the N1MM F# ? I haven’t noticed this.
  • Bob Kupps
    Bob Kupps Member
    edited December 2017
    Hi Matt I mean the CW messages sent by the N1MM function keys.
  • ctate243
    ctate243 Member ✭✭
    what do you have set in the winkey tab here?
  • ctate243
    ctate243 Member ✭✭
    Also, Is you key plugged directly into maestro or into the flex transceiver?  we should be able to nail this down.
  • Bob Kupps
    Bob Kupps Member
    Hi Chris I do not have an external winkeyer just paddles that are plugged into the 6700. It does not make any difference which box I have checked. I set up the winkey com 6 per a video on youtube so maybe I don't need com 6 at all? TU for any help Bob HS0ZIA
    PS **** question but I assume the Maestro software version is what is controlling, not the smart SDR version on the PC?
  • Bob Kupps
    Bob Kupps Member
    After updating the PC SDR to the same version as the Maestro the problem was solved. TU 73
