Antenna Assignment
Richard
Member ✭✭✭
Reviewing the PDF Version of the manual from 4O3A it shows up the Start Up Procedures. One area of concern is not clearly specified. I am sure others have the same issues. In my case I have an Output to my main antennas and that will be on the Output A Position. I also have a separate Antenna that is for 6 Meters. Obviously I am hoping that when on 160 thru 10 Meters that the output is on A. When moving the 6700 to the 6 Meter Band the hope is that the Amp will auto switch the output to Output B. Not clearly shown in the Version 0 manual available from 4O3A. Is this possible with the PowerGeniusXL?
Richard, That’s the way their antenna genius 8x2 switch works and no doubt the amp will as well. I’m sure you’ll receive an official response, but hopefully that quells your concerns.0
The PGXL , if used with a Flex radio cabled for SO2R for example, will follow the antenna port RF assignments associated with the 6700 active TX slice.
All you need to do is run ant 1 on radio to input 1 and ant 2 to input 2 on amp.
Then just set your antenna preference by band, making sure to save it in your profiles.
When you switch bands it will use the proper antenna.
I thought that maybe the Work Around. Personally I was hoping that it would be done internal to the Amp. However, running two coaxes from from the 6700 to the AMPs Ports 1 and 2 respectively then doing the Antenna Assignment withing the radio. Slice 1 be the 160 thru 10 and a 2nd Slice be 6 meters with the antenna assigned to #2. Kind of a "cluge" arrangement but It will work. You would think with the high level of technology that the Freq versus Antenna Assignment would be done inside the Amp. TNX for the information.
TNX Dave....
Had the 6700 a few years and have not really gotten into the Profiles.... About time I do.... Understand Coax from Antenna 1 and 2 on the radio to Antenna Input 1 and 2 on the AMP. Outputs from the AMP, in my case would be Antenna 1 to my 160 thru 10 Antenna. AMP Antenna 2 to my 6 Meters. I understan the Slice Setup on the Radio. Anything done with the AMP?
In the FlexRadio tab of the amp software you just choose your radio for both radios and set TX antenna for radio 1 to ANT 1 and TX ant for Radio 2 to Ant 2. PTT source for both is LAN.0
Should be in the manual when the final manual is published.
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
