Latest WSJT version. No Flex 5000 radio, only 1000 and 6000 series; Anyone ellse had this problem?
Dave Paperman, W5WP
Rig menu does not list Flex 5000
have you tried using the Kenwood TS20001
I don't own a TS2000
My question stated the Flex 5000
Happy holidays
1. Update to WSJT-X 1.8.0 http://physics.princeton.edu/pulsar/K1JT/wsjtx.html
2. Open the WSJT-X settings - radio tab - under rig choose TS-2000.
3. Try again, that setting should work.
4. If it does not, look at your PowerSDR setting, and change it in the CAT control tab to
ID TS-2000.
I use another setting, as my favourite software isHamRadio DeLuxe: I start MiniDeluxe, then use the HRD settings. That works like a charm with automatic logging to the HRD Logbook.0 -
PowerSDR CAT will emulate a Kenwood radio for applications that do not natively support the Flex.
Follow Alex's instructions and it should work.1 -
I followed the recommendations to use the TS2000 emulation. Thanks! That gave me control and synchronization withe the Flex 5000. BUT no virtual audio in transmit or receive.
My previous version of WSJT-X (without FT-8) works fine. I tried comparing settings between versions. All agree but no joy.
I am NOT a software guru. Any help would be appreciated.
Dave, W5WP
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 918 Genius Products
