any recommendation gigabit switch ? for 6700
elan
elan Member
edited October 2018 in FLEX-6000 Signature Series
thank you
vy73 elan g0uut
  • Tim - W4TME
    edited November 2017
    I have been using the Cisco SG200 and SG300 small business class managed switches with excellent results.
  • elan
    elan Member
    edited February 2018
    hello Tim
    thank you kind
    73 elan g0uut
  • Al K0VM
    Al K0VM Member ✭✭✭
    I use Netgear GS108.. Works fine for me
    AL, K0VM
  • elan
    elan Member
    hello AL
    thank you kind for the info
    73 elan g0uut
  • K5CG
    K5CG Member ✭✭
    edited October 2018
    HP 1410-16G (J9560A), runs on 12VDC.
    It also comes in an 8 port configuration, the 1410-8G. I just bought a one of these on eBay for $20 (no power adapter - but you don't need it if you are going to power it from your own DC source).
  • Jim Jerzycke
    Jim Jerzycke Member ✭✭
    Another vote for the 8-port Netgear. I've been using those for years, and have never had one fail. Never had any problems with ports hanging up, dropping offline, or any other technical issues with them. I also appreciate the metal box they use.
  • VK7WH Winston
    VK7WH Winston Member ✭✭✭
    I also use the GS108. Works well for me too. Winston VK7WH
  • AA5JD John
    AA5JD John Member ✭✭
    I too use the GS108. Works very well!
    John AA5JD
  • elan
    elan Member
    thank you all for kind info
    good weekend
    73 elan g0uut
