using 6300 & maestro with mrp40 cw software.
Buford, W4HVW
Does any one have experience using MRP40 CW software with the 6300 . I can receive but not transmit. I cannot get the version for SDR to work at all.
What method are you using to key the radio for CW?
The best method would be for it to use the a WinKeyer emulation.
SmartSDR does support WinKeyer.
Sending CW via Winkeyer USB is now fully supported:
click -Options -TxSettings -Send via Winkeyer
In the pop up window "RS232 Comport Configuration" enter a valid com port number the winkeyer is linked to.
click save
The checkbox "SideTone" allows you to enable/disable the side tone of the winkey device.0 -
It looks like that program is going to send an audio CW tone back to the radio instead of true CW. What are you looking to use it for. Contesting or rag chew I use CW skimmer and my logging software and it works great. I will be happy to help you later this afternoon if youur available Mike NN9DD0
Buford, Maybe this post will help. https://community.flexradio.com/flexradio/topics/flex3000-mrp40-cw-program-is-anyone-using-this-combo Larry ke2yc0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
