Ant RF Gain slider on 6300 with V 2.0.19.98
jean claude
jean claude Member ✭✭
edited December 2018 in FLEX-6000 Signature Series
Due to QRM from plc getting bigger every where, is there a chance to get the gain slider adjustable with my config?
Nowadays it is 0 or 20 Db.
It would be great to be able to adjust the gain at the limit of the QRM.
Tks
jean claude  F6EJU
  • Tim - W4TME
    edited October 2017
    If you are experiencing QRM, you do not want more RF gain, especially on the bands above 14 MHz unless you are using a negative gain antenna.
    This article will inform you when RF gain is needed
    https://helpdesk.flexradio.com/hc/en-us/articles/204923669-How-to-determine-the-amount-of-RF-Preamp-...
    You want to the AGC-T setting to optimize your signal to noise ratio for receive.
    This is covered in the SmartSDR Software Users Guide in the AGC-T section, chapter 13 How to Configure Noise Mitigation
    http://www.flexradio.com/downloads/smartsdr-software-user-guide-pdf/
  • jean claude
    TIM
    Tks for your reply.
    I am going to study what you have explained.
    Tell me one thing:
    On the 6300 is there or not the possibility to adjust the ANT RF GAIN by a slider and not what I have today which is 0 or 20 DB.
    To tell you the true, I have bought the V 2.0.19.98 thinking it will turns the switch in a real slider....
    regards
    jean claude
  • Tim - W4TME
    edited October 2017
    The RF gain control is not continuously variable.  It has fixed gain settings in steps.
  • jean claude
    edited October 2017
    Do all models 6000 have this function working in the same way ?"fixed gain"
    I am gonna get a new 6400 when available on this side of the pond ...2018
    Will it be as all the 6000 with a fixed gain?
  • K0FLY
    K0FLY Member ✭✭✭
    Jean:
    What your adjusting (RF Gain) is known as PRE AMP on/off in other radios.   Look at the slice flag, click on the speaker Icon, you will see the box for selection of AGC Speed.  To the right of that is a slider, this is the variable parameter you are looking for, FLEX calls it AGC Threshold, it would be labeled RF gain on analog radios.
    Gayle K0FLY
  • jean claude
    Thanks Gayle.
    73 f6eju
  • Tim - W4TME
    edited October 2017
    Yes, all FLEX-6000 operate this way, they have a stepped gain RF preamp.
  • jean claude
    edited November 2017
    Tim
    Now It is clear  in my mind.
    Thanks for your help and patience...
    jean claude F6eju
  • Tim - W4TME
    You're welcome
