monitor goes blank on transmit
Salty Z
flex 6300 FT8 on WIN10 ON Transmit or autotune the monitor goes blank(off) and the picture only returns after the transmission is over
samsung cf791 works otherwise well; have changed the settings in windows playback without effect
Any ideas about this?
Possibility RF is getting into your radio. Try the same by reducing your power substantially.
Jim, K6QE
Honestly sounds like you have a monitor that is suceptable to RF.
Two things Salty.
I suggest installing snap-on toroids on the video cable possibly the power cable as well.
Second you might want to try a different monitor.
Personally I install toroids on everything whether I need it or not, having lower close antennas and high power I error on the side of prevention. Call me paranoid.0 -
Ok so I just took a look, nice monitor. That would be a shame so try getting physical separation between the transmitter, feedline and monitor. Make sure your coax doesn't cross over the monitor cable.0
How is your monitor fed, i.e., is it HDMI, VGA, or digital? I would try to change the cable first and then change the video mode if that doesn't work. VGA cables are very susceptible to RF, which is why many of them have ferrites built in. You may want to try one of those.
You may also want to look at your station grounding. Is everything grounded to a central point? Solving the problem at the source is always good if you can.
If you have one, you may want to try a different monitor just to see if the problem persists.
YES sound like RFI in the Shack here is a great reference every one on HF should have this PDF handy.
https://shure.custhelp.com/ci/fattach/get/82797/0/filename/RFI-Ham.pdf
73's
I will add my opinion to the consensus and mention that when I first got my rig and was anxious to get on the air, I operated without an RF ground. On many frequencies everything was fine, but on some, my monitors went snowy.
73, Bob WK2Y0 -
66 pages of golden information. Met Jim Brown at a W9DXCC many years ago. Made me a believer. Mr Brown has devoted so much time to common mode issues. WX7Y thanks for the reminder and link. I keep this pdf on my desktop.0
The problem was solved after I deleted both wjst and ssdr and reloaded. I thought it might be corrupted drivers interfering with the monitor.
I appreciate all your suggestions and will follow all these as well
Thanks0 -
Now that's a new one for the books. Thank you for updating Salty. Making a mental note of this one for future reference.0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
