DAX error
Geert Balsma PA3CPS
This morning i startup my computer (Windows 10 64b 1703) i get a DAX error. I have manually uninstalled the DAX drivers en installed again. Same error.
I also totaly remove Smartsdr v2.0.19 + DAX + CAT from my computer and installed again. Same error.
On another computer (windows10 64b 1703) i installed SmartSDR + DAX + CAT. Same error.
Anyone recognize this problem?
Wish I had a solution to offer but I can tell you that I get something similar when I power off my rig before shutting down all of the connected software. Not a graceful exit when besides SmarSDR, CAT and DAX, there are multiple third party apps left hanging. When it happens, I just boot.
73, Bob WK2Y0 -
solved the problem: factory reset the flex.0
What ever it takes.
This doesn't relate to your problem, but frequently when I bring up my Flex, the CAT says the radio is not connected. It seems to happen randomly. I just click over the warning radio not connected in the CAT window and it connects immediately. Also notice that CAT and DAX don't work on SmartSDR remotely unless I use my VPN. Also notice I get less latency on VPN than on Smartlink. I use OpenVPN on my Asus routers and Softether on my iPhone/iPad. It is my understanding that Smartlink operates peer-to-peer, so don't understand why my VPN gives better performance than Smartlink.
Jim, K6QE
My problem was not totaly solved. Get no connection to my radio. Delete all software + SETTINGS. Install SmartSdr, add com ports in smartsdr-cat and import my profiles. Works perfect now.0
- 690 The Flea Market
- 197 SmartSDR+
- 112 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
