SDR settings for SPE 1.3K amplifier
Which serial cable are you referring to? The USB cable is for supervisory control of the amp, such as switch on/off and all of the control menus.
The CAT serial cable via the 15 pin is strictly for radio to amp communications (CAT).
The other serial 9 pin cable next to the USB I've never tried. Theoretically though it's the same connection with the USB just being a USB to serial converter.0 -
My serial cable is a real serial cable, with on both ends 9pins connectors (male/female).
The connections i made are in the SPE manual.
When i use a USB-cable it works perfect. Then i can switch my amp on/off
You might want to ask them then. You probably bought it from Hamshop in the Netherlands? They do the service for it. Or whoever you bought it from. They will know the answer. Sorry, I don't have one anymore otherwise I could check myself.
Ria0 -
Are you using the port connector? It is a while since I made my cable, but it is not a usual straight thru serial cable.
Also, i dont think that remote on-off works with the Expert RS232 app. I apply/remove +12V to the relevant port connector pin to toggle on and off.
Steve, M0BPQ0 -
See page 46 of the manual at http://www.expertlinears.com/pdfs/expert_1-3K_manual.pdf for the port connection if that is relevant.
73, M0BPQ0 -
I was able to turn off/on from the app using the USB cable. I have never tried the 9 pin port connector.0
Didn't Dan Tassell make a custom cable that includes powering on the amp when the Flex is powered up? You can email him at mailto:kc5pcb2@att.net?
I personally use DDUtil to control and power the amp on & off.
The power cannot be turned on and off thru the remote software if using the serial cable.
You can use Dan's cable, which includes a dip switch to enable the remote on feature. With this enabled, anytime you remote enable the Flex, the amp also turns on, and off.
As a side note, when using this cable, anytime you turn on the Flex, using any method, the amp also turns on and off. Which is nice (assuming you want the amp on when the Flex is on).
/Doug0 -
Hello Ria and the group , Picked up my Flex 6600 this past Wed. I'm reading this thread about the cables needed between flex 6600 and SPE amp . In my case SPE 2kfa ! I have everything needed to wire the cable as Ria shows above . My question is , do I also need a USB to Serial adapter cable ?? I understand Amazon has the correct one ? Can someone send me a link please ? Do I need both the DIY Cable and the USB to Serial adapter cable ?
Thn Ed
I'll let those with more technical knowledge comment, but I believe if you have an old-fashioned 9-pin RS232 port on your computer, you won't need the converter. If you want to hook up to a USB port, either on your computer or go directly to the Flex, you'll need a genuine FTDI USB-RS232 adapter.
https://www.amazon.com/gp/product/B01MCZM6OM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I'm using one of Dan's cables that came with my (used) SPE 1.3k and using the adapter, and have it going directly to the USB port on my 6400 instead of going through the PC. My particular cable has the PTT wiring to the Flex accessory jack so it doesn't require the additional RCA cable that is usually required. As you can see, there are multiple alternatives. With my setup, using FRStacks, I can switch from standby to operate, and select the power level without touching the amp. I only need to use the SPE front panel if I'm resetting the antenna tuner or the drive levels. I really love the Flex/SPE combo.
Rick, W0FG0 -
There is a newer SPE 1.3k firmware that takes care of the Fans spinning up too soon.0
From SPE
11_10_17_C_15s
- Less noise: PA fans are always off if the temperature is lower than 35C
- Tunable antenna and RX antenna settings are saved for every memory bank
- LOW power level can be set per band by arrow keys down to approx 250 Watts
- The RX antenna can be momentary disabled by pressing the key ANT
- General code maintenance
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
