6300 vs 6500 for CW contesting?
VE3WDM
I soon am going to be purchasing either a 6300 or 6500 I am 80% CW and 20% digi. I take part in lots of CW contests and was wondering if there was any difference between the 6300 vs the 6500 for this type of contesting. At this time I own an Elecraft k3.
VE3WDM
VE3WDM
I made a switch from a K3 to a 6300 and after 3 weeks traded it in to Flex for a 6500. Main reason was 4 slices compared to 2 for the 6300 an advantage to any contester be able to see that much more. I'm a phone and digital use here and the digital mode with DAX is excellent with very good reports on phone also, very easy to setup the mic's and with all the controls.
A good reason to buy either from Flex preowned is a full 2 yr warranty and the latest software installed.
Mike, I am not into CW, but I have a very happy experience to share. Recently, I traded my 6300 for a 6500. The difference in receive audio is a significant improvement. I would highly recommend going for the 6500. I use mine with an Elecraft amp and antenna tuner. Perfect compatibility. Good luck and 73, WO5E.0
Mike in my opinion the key value of the 6500 over the 6300 for contesters here are the inclusion of contest band pre-selectors(and to a lesser degree slightly better dynamic range). I also agree that a pre-owned 6500 would be a good value for you. You can reach out to VA3MW and he will help you out.0
Hi Charles,
Curious about your statement on receive audio. Assuming all other things being equal (same speakers and / or headphones), why is receive audio better? Was it different settings you used in each radio? I'm now wondering if there is a difference in the receiver audio circuits between the 6300 and 6500? I had assumed both radios have same audio output circuits--maybe I'm wrong. I'm just learning more about the Flex radios and considering new vs. older signature models.
Also listening fatigue is important me so better receive audio can help on that.
Has anyone else who made the change notice this difference between 6300 and 6500?
Olaf W9FY
A 6500 over a 6300, definitely. If I were to buy today I would go for a 6700 (which I have) or the 6600 if budget was an issue.1
I agree if I would have the extra cash I would have went with 6700 because of Diversity Receive alone, and with 4 more slices.
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 36 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 983 Third-Party Software
