Newbie with 6300. Can I use transvertor input as Rx antenna input?
Roy Higham
I've just bought a 6300. Arriving Monday. I already have a 1500. I use a Wellbrook Loop for Rx and end fed wire for Tx. 1500 is fine with this. I must not transmit into loop! Can I set transvertor input socket as Rx ONLY on 6300? Thanks Roy. G3VDS Have just seen earlier post from Salvador which tells me how to do it. Thanks. I can't wait to get my hands on this radio !!
Roy, Yes, you can use the transverter IN for a RX antenna.
73... Bill K3WA0 -
Thanks Bill. I wonder if anyone knows the isolation figures. I had no trouble with 1500 but there's 20x the power !0
I don't know if there's published figures. I have used the xvtr in jack for RX antenna since I got a flex a couple of years ago - first with a 6300, and later with my 6700. I have run 100 watts, less when I use my amplifier. Never a problem. Good luck and have fun with it.
73... Bill0 -
Roy I have close receive antennas, a ewe and pennant, run an Acom 1000 on the 6300, flawless, never an issue on the xvtr port.0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
