SPE Expert Amp 1.3k FA QSK/QRQ
Lewis Cheek
Anyone using the Expert 1.kk FA with high speed full break-in, and if so how well does it perform, where does it ( speed) fail to switch, if it does fail ?
Looking for something that will run full output/full break-in/QRQ without issues.
My Elecraft KPA-500 works well, but it's low power. My Acom 1500 will run full break-in but NOT QRQ.
Lew
N4CO
Lew
N4CO
I do and I put 30ms delay just in case. However they claim that it can switch very fast. Hasn't been a problem for me. I haven't really gone faster than 40wpm0
Ria -
Setting up my 1.3k. Which delay did you set at 30ms?
The 'Delay' in SmartSDR "P/CW" panel?
The delay in Settings > Radio Setup > TX > RCA TX1?
The delay in Settings > Radio Setup > TX > TX Delay?
Three delays are possible.
73 John K1ESE
The last one.2
You might want to consult the manual but if I remember correctly.
P/CW panel is actually delay added to end of TX before RX
RCA TX1, 2, 3 are delay at start of TX
TX Delay is an additional delay added to whatever is in TX1, 2, 3
I typically put the delay in the TX1, 2, 3 depending what line I am using for PTT control.1 -
That’s what I do as well. Prevents chopped off dits at the beginning.0
I'm confused. Ria, do you put it in
as you said earlier or in
as you are saying now?
John K1ESE
Ria,
I have 6300 and SPE Expert 1.3K FA amp here. Reported key clicks on Top Band alas. I had no delays set and just set your suggested 30 TX Delay. Alas, I have a remote MFJ 998 tuner at the base of my Marconi Tee with elevated radials for Top Band and it will not retune as I qsy in a contest with high power so SWR sometimes gets over 2:1 and that is when I am getting reports of bad key clicks. I try to retune as I move with exciter only at about 20w frequently but sometimes don't notice soon enough swr getting up near 2:1 where seem to have key click problems. A nice one or two second tune from the exciter would be nice but don't see a way to set that up using that tuner remotely alas. Maybe the TX delay with help -- I will be testing with local station later today hopefully on that. Any ideas?
73 K5HK - Carl0 -
Hi Carl,
Sorry to hear you're having key clicks! I've since sold my 1.3K-FA in anticipation of the PowerGenius XL amp. SPE claims they had special contacts on their relays which do not arc. Hmm. Maybe you can ask them. Sorry.
Ria, N2RJ0 -
Ok Ria,
Thanks for all you comments. I'll take it up with SPE and MFJ on the remote tuner side.
Carl K5HK0 -
I've been running my 2K-FA without any delay on break-in and it seems to be doing quite well. Not one report so far of funny stuff going on.
But since I'm not contesting and trying to be the fastest guy on the band I'll probably put in the short TX delay as well. It certainly cannot hurt.
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
