Bought used 6500, required S/W downgrade, but green light doesn't stop flashing
Victor Gavron
I bought a used 6500, and when I tried to install the S/W (1.6.17.156) it notified me that I needed to downgrade. So I clicked the button in the app, the sliding marker that shows progress moved from left to right, but when it completed, the green light on the 6500 would not stop flashing. I waited 2 hours, and turned it off (holding the button for 4 seconds). Now when I turn it on it still flashes green on and off. Based on comments, I have moved the Ethernet cable from the PC to the router, no effect. The Ethernet light does flash, but when I check IP addresses, the 6500 doesn't exist. Any help would be welcome. Is there a way to reinstall the firmware, if needed?Thanks...
Try a factory reset. Hold the OK button down, and then, momentarily press the on/off button. Wait for the LED indicator to count down and release the OK button. After the radio boots up, try to reinstall.0
Here is a link on how to do the factory reset. If this does help get you running again you should open a support ticket with FlexRadio https://helpdesk.flexradio.com/hc/en-us/requests/new
https://community.flexradio.com/flexradio/topics/factory-reset-6500
What version of SmartSDR did you have installed on your PC when it notified you a downgrade was needed. My guess is the radio was running more current version than what you have installed on the PC. I could be wrong.
A question the is off topic but relevant. What version of software is it downgrading from. If it was version two the radio owns the software you should upgrade your software. Just something to check. As for the hanging green light try the reset as suggested Mike NN9DD0
What software version was loaded?
If 2.x was loaded then you're radio might already be licensed for that and you should have no troubles. $200 saved.
But if the license is not valid or you don't want to license it for 2.x that then go to v1.11.02 or v1.10.16. This avoids any dependency issues between versions.
Kev0 -
always install the latest version
I wouldn't recommend downgrading firmware, I tried to do it on my 6300, from v.2.1.9 to v2.2.1.7 now my radio Doesn't work, I just sent radio back to Flex. For repair.0
If a cold boot (removing DC power, reconnecting DC power and rebooting the radio) does not resolve the issue, then I suggest you submit a support ticket via our HelpDesk (https://helpdesk.flexradio.com) so we can assign you a case number. For details on how to submit a HelpDesk support ticket, please refer to the following URL: http://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Supp... Once the support ticket is submitted, a support engineer will be in contact so we can work on the issue.1
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
