Two Tone signal input ?
Larry, what does your flex level meter show? Trying to figure out how hard you are driving the flex. I have installed the iBox and am still getting bumps although not quite as bad. No where as good as yours.
The level meter gain is right up to 0 db without going over.0
Thanks Larry. I just put a post on the Yahoo group.
I finally made it to the top of the list and my LP-700 order will go in tomorrow. Any update on best practices for interfacing the 2 tone generator to my 6700?
Mark
W6MSB
Mark, I would order a iBox from Julius and cut to the chase. For a clean two tone signal you need to isolate the LP500/700 from the Flex. You will likely need to adjust the level as well. The iBox does both.
If that does not do it, you might have to mess with the power supply ground if you have an Astron but I think it most cases the iBox will do it.
Did you change the input selection to not use the balanced mic when you use the 2 tone signal?0
Hello Larry.
I also am battling the hum and low level on my 6300.
Can you send any drawings of your transformer connections ?
Where do you have the EG settings ?
I find the mike control has no affect on the level on pin 1.
Cecil-W4CM
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
