Old & New Maestro price
Patrick Moonen
There would be a new Maestro model with a screen that would have higher resolution. The price of the new Maestro would be the same as the model being offered for sale. The price of the Maestro now is 1299 euros in Germany.
73 Pat
73 Pat
Hi Patrick
The old and new Maestro do have the same screen resolution. There is no visual difference between the 2.
Mike va3mw
Hi Mike,
Thanks for the info Mike.
Pat ON3CQ0 -
Technically the "new" Maestro is not a new model, as it has the same specs and price as the original version.1
Technically -- Tim is correct ... LOL0
So... no new Maestro, and the Maestro price remains at $1199 US, correct?
Yes. There is only the Maestro we are shipping today. Same price. Same functionality.
Tnx for the link Chris.
I received my Maestro 2 days ago. Works good. Only problem I have is they took out the charge cable for the battery. You nkw have to remove the battery and plug the battery into a wall wart. Kind of sucks. A 10000mah battery will last about 4 hrs.0
The charging cable option was removed on all Maestros because of potential fire hazard by charging Li batteries inside the unit. Use a second battery bank for swapping out the discharged battery and charge the battery using the manufacturer's instructions. The Maestro display battery will keep the unit running long enough to swap the batteries without having to power down the unit.0
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
