Old & New Maestro price
Patrick Moonen
edited April 2020 in Maestro
There would be a new Maestro model with a screen that would have higher resolution. The price of the new Maestro would be the same as the model being offered for sale. The price of the Maestro now is 1299 euros in Germany.
73 Pat
  • Mike va3mw
    Mike va3mw Member ✭✭
    edited July 2018
    Hi Patrick
    The old and new Maestro do have the same screen resolution.  There is no visual difference between the 2.
    Mike va3mw
  • Patrick Moonen
    edited September 2017
    Hi Mike,
    Thanks for the info Mike.
    Pat ON3CQ
    edited February 2018
    Technically the "new" Maestro is not a new model, as it has the same specs and price as the original version.
  • Mike va3mw
    Technically -- Tim is correct ... LOL
  • KF4HR
    KF4HR Member ✭✭
    So... no new Maestro, and the Maestro price remains at $1199 US, correct?
  • Mike va3mw
    Yes.  There is only the Maestro we are shipping today.   Same price.  Same functionality.  :)
  • Patrick Moonen
    Tnx for the link Chris.
  • Merle Watts
    Merle Watts Member ✭✭
    I received my Maestro 2 days ago. Works good. Only problem I have is they took out the charge cable for the battery. You nkw have to remove the battery and plug the battery into a wall wart. Kind of sucks. A 10000mah battery will last about 4 hrs.
    The charging cable option was removed on all Maestros because of potential fire hazard by charging Li batteries inside the unit.  Use a second battery bank for swapping out the discharged battery and charge the battery using the manufacturer's instructions. The Maestro display battery will keep the unit running long enough to swap the batteries without having to power down the unit.
